Is there any way to reverse the animated brush in a click?
Soom
Post by Soom »
The question in the topic...
Re: Is there any way to reverse the animated brush in a clic
X and Y
Soom
Post by Soom »
But this flips the brush - I need to reverse just the playback. I can select Ping-Pong, then it will play back and forth, but what I need is only back
Oh sorry, I misunderstood you. You can only do it when it's linked to a connection.
However, you can also apply your brush on as many images as you need, reverse their order and cut it again.
If you need to change this mode often, indeed it's not the faster way to do it.
Soom
Post by Soom »
Elodie wrote:Oh sorry, I misunderstood you. You can only do it when it's linked to a connection.
what is the connection thing?
yes - about creating two brushes I figured, but it's not the best solution. I think it could be a feature request.
Soom wrote:what is the connection thing?
Pressure, Speed, Altitude, etc.
I moved the topic to the correct section.
Soom
Post by Soom »
Oh, ok, I understand. So we need just need a Reverse playback option -I believe, if you have Ping-Pong it's not a problem just to drop half of it? :)
Obviously :)
> to do list !
