Relative Path to dependencies
- schwarzgrau
I'm working on more than one computer, but always keep the whole folder structure in sync. Unfortunately I have to relink all dependencies every time I switch the computer, cause their path seems to be absolute. I know I could implement all dependencies in the project, but often it would get a huge file. So I thought maybe their could be a way to choose if the path is absolute or relative. Maybe a little checkbox in the import-window.
- NathanOtano
Re: Relative Path to dependencies
I also really need this, same for the scripts libraries and configs
try this:
tv_GetPath
Path = result
tv_warn "path = " Path // see what it gives you
then experiment with the command and any of these arguments:
tv_GetPath HOST|TEMP|CONFIG|PLUGIN|GEORGE
for example:
tv_GetPath "george"
GeorgePath = result
tv_warn "GeorgePath = " GeorgePath
you can concatenate the resulting GeorgePath-variable and your George Script name so you can load the same script on either of your systems.
Now see if this lets you use the same, unchanged button/script on both systems.
tv_GetPath
Path = result
for example:
tv_GetPath "george"
GeorgePath = result
- NathanOtano
Svengali wrote:try this:
tv_GetPath
Path = result
for example:
tv_GetPath "george"
GeorgePath = result
Ah! Nice
