Animated paper texture behind the pen.
daninski
Post by daninski »
I can't see anything about this after searching the forum. What I'd like to be able to do is have a cycle of 3+++ paper textures under the pen. Before TVPaint I'd do this in AE but I'd like to know if it's possible within TVP. The problem I have with the current set up is that the paper-under-pen texture stays the save as the line animates through the frames. This gives the impression that it's just multiplied onto a still image rather than being animated on individual sheets of paper*... does this make sense to anyone? :D
First post btw, HI THANKS HI!
* I know you'll never get 100000 textures in there but a cycle of many works great.
http://www.daninski.com
Re: Animated paper texture behind the pen.
I put some 3 or 5 textures into an animated layer and loop it, then set this to mask and draw on a different layer. You can set the paper layer to invisible, it still works. Only problem is you can't easily adjust the paper's strength, so you have to test a percentage firs, then make it permanent within the layer by merging with white.
daninski
Post by daninski »
That's a shame it's not under that paper button. Would have made it useful for more than just illustration.
http://www.tvpaint.com/doc/tvp11/index. ... re&lang=en" onclick="window.open(this.href);return false;
Use [Rendering > Inlay Texture FX] with an animated source.
daninski
Post by daninski »
Ah ha! So this will let me have boiling paper under my pencil line rather than a static one? I don't want a tracked texture either.
I'm slowly going through the documentation at the moment. So much in here.
it's an effect, so you apply it after you have animated shapes without textures.
daninski
Post by daninski »
slowtiger wrote:I put some 3 or 5 textures into an animated layer and loop it, then set this to mask and draw on a different layer. You can set the paper layer to invisible, it still works. Only problem is you can't easily adjust the paper's strength, so you have to test a percentage firs, then make it permanent within the layer by merging with white.
I'm trying this method but it seems to me that the mask only responds to alpha and not luma - so I can't get my paper textures to affect the line. Is there anyway to luma matte?
Use the scan cleaner on the textures?
daninski
Post by daninski »
slowtiger wrote:Use the scan cleaner on the textures?
Oooooh reeeeally? I shall try that in the morning. So the scan cleaner will give graduated alpha values to the image I assume?
exactly,
black => 100% opaque, white => 100% transparent, middle-grey => 50% opaque, ...
but take care to "flatten" the profile curve of the ScanCleaner effect before applying it,
otherwise you will get a little "distorsion" in the Luma>Alpha conversion.
daninski
Post by daninski »
It would be a nice feature if you could do this under the paper tab for the pens. Any thick lines over a few frames show up the static paper which breaks the analogue illusion a little.
I found a useful workaround to prevent a paper structure from remaining static over several frames.
1. Colour every 3rd image only with the paper of your choice.
2. Set paper angle to 120°.
3. Colour every image after the already coloured image.
4. Set paper angle to -120°.
5. Colour remaining images.
This works nicely for me on two's, but I only use a gray wash.
Something else :
1) You apply flat colours on a layer
2) You add above a new layer and you apply a paper on - let's say - 5 instances. On each instance, you change the angle, size, whatever, so you have 5 different instances
3) Use "Loop" post-behaviour
4) Use a blending mode, such as erase, saturate or tint.
5) You'll get an animated paper
Animated-paper.tvpp.zip
(3.92 MiB) Downloaded 1527 times
