Hey!
Two more little suggestions to discuss that i made in the french section, before going to bed.
The first is really simple : sometimes i really need an on/off button for the out of peg function. It's really awesome to be able to move your other image but the problem is that you lose it's first position. After that it's really hard for managing the spacing... You can flip to the out-of-pegged image you see where it is originally but all the images around will move to, not really handy. You can also desactivate the out of peg, but you need to set it again afterward.
A simple shortcut for having a sight without out of peg would be cool also (why not having both? The original position+the out-of-pegged. A possibility).
You can also duplicate the frame to have both the original and out-of-pegged versions in your lightable or use w but it's not the most handy neither.
Also i was thinking about looping the navigation. Like with the bookmarks (when you leave the last it comes to the first), but with also the instances and the image markers (that's the name in english?). Not with the images i think, because sometimes you want to go out of your layer boundaries to break a new instance here.
Maybe it coudl also check the beginning and ending of the playback range if it's activated to be able to check only a selected area.
It could possibly depend of the post-comportment repeat?
Out of peg On/Off button + Looping instance navigation
- NathanOtano
Re: Out of peg On/Off button + Looping instance navigation
I like this idea : beeing able to switch on / off the OOP without switching on / off the LT or erasing your OOP positions.
