Multiplane
Multiplane
Is there a tutorial out there on setting up a scene with a multiplane camera?
TVPaint Animation 10 Pro
Re: Multiplane
No video tutorial that I am aware of , but in the User Manual the chapter 'Lesson 16' is a tutorial in how to use the Multiplane Camera .
http://static.tvpaint.com/downloads/man ... sson16.pdf
The project file used for the lesson is found in the Folder of "Contents & Examples" which can be downloaded here:
http://www.tvpaint.com/v2/content/artic ... amples.php
The project file is named MPC.tvp
Re: Multiplane
When I export the file to AVI, I don't see the camera move. How can I export the move?
Re: Multiplane
have you applied the multiplane_fx on the animlayer content, or just previewed it without applying ?jbird013 wrote:When I export the file to AVI, I don't see the camera move. How can I export the move?
Re: Multiplane
thought I had. Didn't realize you needed to select all the images to apply it. Got it, thanks.
Re: Multiplane
More mulitplane camera questions
When you change the values to one of your planes to resize or change y values over the course of your scene, does setting the key for that one plane set keys for all the other planes?
Is there some way to know which keys apply to which plane?
If you set the top key are you setting all the keys?
Can you move the keys up and down the timeline?
Is there any way to make a layer temporarily transparent in preview so you can see the layer underneath to which you are applying values?
Thanks
TVPaint Animation 10 Pro (10.0.14)
Thanks
Re: Multiplane
jbird013 wrote:More mulitplane camera questions
Thanks
I wish I had some quick and easy answers for you. I have to confess that the Multiplane Camera baffles my brain and I usually feel like I'm re-learning it every time I use it (which is not often , so I think that's part of my problem. It's not the fault of TVPaint , it's because I don't use the tool often enough ; regular use of a tool is necessary to become adept with it and honestly I've never worked on a project in TVPaint that required sustained use of the Multiplane tool. Mostly I've just "played" around with it . I need to learn it better. )
I'm sure this is also on the long "To-Do" list of video tutorials that need to be made.
Here's one thing I think I can answer for you before someone from TVPaint chimes in on the more complicated questions:
If you click on a keyframe + so it is highlighted yellow + you can hold and drag it to another point on the timeline .Can you move the keys up and down the timeline?
Also , on this question :
if I understand you correctly , I think you can just use the slider to dial down the opacity on the layer to make it transparent, so you can see the layer underneath .Is there any way to make a layer temporarily transparent in preview so you can see the layer underneath to which you are applying values?
Re: Multiplane
... or use the layers attenuation option in the preview panel, (TVPA 10.5.x required).D.T. Nethery wrote: ... Also , on this question :
Re: Multiplane
You should update !jbird013 wrote: TVPaint Animation 10 Pro (10.0.14)
Re: Multiplane
Thanks. I've been exploring other issues, but these comments were helpful.
