Hi,
I found that the 64-bit version of TVPaint 10.5 on OSX crashes when I connect or disconnect an external display to my laptop. I'm not sure if its new in 10.5, because I previously used the 32-bit version. I will check this when I can.
The crash is completely consistent, and it happens when I connect/disconnect an external display and also 'close the lid/open the lid' when an external display is connected. Every time the OS is switching display configuration.
There is also a problem with exporting image sequences. Basically I try to export a sequence to a directory that already contains files from a previous export, and it only will export a single file.
Only after I change the settings back and forth and try to export several times, it will export the sequence.
On one occasion it only exported half of the animation. so I had to try again and then it worked. I think it happened on an empty folder as well.
Thanks.
Two bugs on TVPaint 10.5 64bit OSX
Re: Two bugs on TVPaint 10.5 64bit OSX
bug confirmed
This is indeed new in 10.5, and specific to the 64-bits version.oferk wrote:Hi,
I'm working on a fix.
On holidays until May 5th
Fixed for next releaseThierry wrote:This is indeed new in 10.5, and specific to the 64-bits version.oferk wrote:Hi,
