can anyone tell me how to deactivate the cammera?
krycekuva
Post by krycekuva »
i just receive a scene with a cammera movement in it. and since this movement is going to be done in AFX i dont see it necessary to work with in TVP. long story short, i just want to delete the cammera setting as i dont want the image to move from frame to frame.
can anyone tell me how to?
i also manage to alter the cammera movement. but now it is fixed in the middle of the picture, and when i play it, i only see what happens in that center and not in the entire image.
Re: can anyone tell me how to deactivate the cammera?
1. Is it a TVP file with a TVP camera movement, or is it some other video which was shot with a moving camera?
If first, just switch off the TVP camera.
If second, you may use FX > Stabilization 1 or 2 point. See manual.
if it's a camera moving set in your tvpa project, you can simply disable the "Camera View" option of the preview window (or of the remote panel),
if you really want to definitively delete the moving, hit the camera button, in the camera tool panel > Command / Reset.
