stamp in place for multiple frames
I'd love it if you could use enter to repeatedly re stamp in place with the cutbrush or if you could select multiple frames and stamp in place
...::http://www.runeryberg.com/::...
Re: stamp in place for multiple frames
For that I use this key command combo:
Tools: Draw Dot+Layer: Next Image
it works here,ryberg wrote:... or if you could select multiple frames and stamp in place
if your sequence is already timed (exposed), make a custom button with these 2 commands :
Tools: Re-Apply Custom Brush
Layer: Recompute Exposures
arrow, enter, repeat?
doesn't "Re-Apply Custom Brush" need you to stamp the brush once in order to re apply or is it simply stamp in place right after you cut it out?ZigOtto wrote:it works here,ryberg wrote:... or if you could select multiple frames and stamp in place
if your sequence is already timed (exposed), make a custom button with these 2 commands :Code: Select all
Tools: Re-Apply Custom Brush Layer: Recompute Exposures
and, yeah, I also need to recompute my instances even though auto create instance is switched off.
make the 2 commands button mentioned above and try it ... you'll get the answer by yourself !ryberg wrote:...
in fact, no, "Re-Apply Custom Brush" applies it at its original place (at least it's how it works here), doesn't need to be applied once before.
btw, what's your tvpa version ?
well, it seem like I created some confusion since I'm using one of Juuls Actions to stamp in place which includes a smart function for the smoothing of the cutbrush. That action can not be applied to several selected frames.
I can do that if I simply hit the stamp in place under the cutbrush options or create an action like ZigOtto suggested. Thanks for that.
What I was aiming for in the first place though, was for enter to work as re apply for stamp in place as well.
