here's briefly the way to use the
Canon Plugin with TVPA :
* previously required :
- the canon driver of your camera correctly installed in your system, (Windows only at this time),
- a compatible canon camera (see the list zipped in the file) powered and plugged to your computer (usb connected)
- set your camera in "playback" mode, (not in "shooting" mode, to be able to drive it via the computer)
how to use it :
- launch TVPA, open the Video Grab panel (menu Windows/Video Grabber),
- in the device list, choose your Canon camera (if other devices are listed),
- hit "settings" to access the second panel, in which you have to adjust your grab settings
- choose "apply in current Layer", so it will append the new image just after the current one,
- when it looks fine in the little preview, hit "Grab input", a sound ring out when it's done.
(see pict.1)
tips :
a) to preview the next-to-shoot image (low-res. finder preview) over your last grabbed frame,
enable the [V] button, and tweak the mix (video/current-frame) value, (see pict.2)
b) to preview your begining animation using the LightTable, set the Layer opacity to half (or a bit less),
set the previous frame color to "none", and tweak the level sliders of the 1, 2, 3, ...5, 6 previous frames
to make them visible, (see pict.3)
of course, you can use a) = display with video, and b) = LighTable enable simultaneously.
c)recommended: always close your Video Grabber panels before to quit TVPA.
hope it will help someones around here.
in French :
en bref ci-dessous la marche à suivre pour démarrer avec le
Canon-Plugin et TVPA :
* conditions préalablement requises :
- le pilote canon de votre appareil numérique duement installé dans votre système (Windows uniquement à ce jour)
- un appareil canon compatible (voir liste jointe dans le fichier zippé) alimenté et connecté au port usb de votre ordi,
- mettez l'appareil en mode "lecture", (pas en mode "prise de vue", pour pouvoir le piloter depuis l'ordi),
comment ça marche (
spécial dédicace to M. Chevalet):
- Lancer TVPA, ouvrir l'interface "Aquisition Vidéo", (menu Fenêtres/Aquisition Vidéo),
- dans la liste "périphériques", s'assurer que l'on a bien l'APN canon sélectionné (si d'autres périph. présents)
- cliquer "Réglages" pour ouvrir la seconde fenêtre dans laquelle vous allez pouvoir modifier vos réglages,
- sélectionner "Destination/calque courant" ainsi l'image acquise sera ajoutée à la suite de l'image courante,
dans le même calque d'animation,
- quand limage dans votre mini-preview vous semble satisfaisante, cliquer "Acquérir l'Image"
(ou "Entrée de l'Aquisition" pfff...), un son retentira dés que l'image a été prise et transmise. (voir pict.1)
conseils pratiques :
a) pour afficher l'image à prendre (le retour de l'écran de controle de l'appareil) en surimpression
par dessus la dernière image prise, activer le bouton [V], et ajuster la valeur % "Mixage" (video entrante/image courante)
(voir pict.2)
b) pour voir le début de l'anim en utilisant la table lumineuse, régler l'opacité du calque à 50% (ou moins),
sélectionner dans la fenêtre Table lumineuse l'option "colorisation avant" = Image, et ajuster les curseurs
de niveau de transparence des 1, 2, 3, ... images précédentes que vous souhaitez rendre apparentes.
(see pict.3)
bien sûr, vous pouvez cumuler a) = la vidéo mixée à l'image courante et b) = l'aperçu via la Table lumineuse des images précédentes,
c) il est recommendé, une fois la session d'aquisition terminée, de fermer les 2 fenêtres d'aquisition vidéo
avant de quitter le programme TVPA.
voilà, les Trnka, Aardmam et autre Tim Burton en herbe, à vos souris ...
et n'oubliez pas de poster vos oeuvres dans la users Gallery!
ps :
ceci n'est pas un tutorial, loin s'en faut, juste un mini coup-de-pouce pour ceux
et celles qui pourraient en avoir besoin pour se mettre le pied à l'étrier.
