I'm using the demo at the moment. I think this is the program I read about a while back that was used in a few Gobelin shorts.. I think it was Le Royaume. It seems like a really nice program.
I've been working on a walk animation to put over a video.. finished the whole cycle and would like to shrink and repeat it. How can I select an entire layer of frames and move them in the timeline? How would I select an entire layer of frames and resize them all at once?
Also, is there some form of chat/irc I could use to ask small questions like these?
Thanks for any help I get!
A few questions about TVP!
Re: A few questions about TVP!
Welcome, Josh,
There are a couple of ways to do this but since you want to shrink your cycle, repeat it and move it, the best way to do all of this at the same time is to use the KeyFramer. This has been discussed so many times in many threads that I suggest you use search (right top corner of this page) and if you have more questions, come back and ask away -- you are in the right place. Usually you will get straight away answers around here but you have picked a bit of a complex question that usually needs to be explained at length, and as I've said, already has been answered elsewhere so I won't go into this myself right now -- it's not a snub.
