peg hole registration reduce quality
dandov
Post by dandov »
When I do a peg hole registration for my scanned frames, the quality of the scan reduces considerably.
Does any-one know a way around this?
Thanks!
Re: peg hole registration reduce quality
Not sure if there are othere methods but...
one way would be(though a lot of extra work for you probably)
to use scans of a higher resolution then needed for the project so that after registration you can scale down to the right resolution.
dandov wrote:Hello,
Thanks!
Can you post some screen shots showing what you mean by "the quality of the scan reduces considerably."
I haven't noticed any loss of quality in the scanned images when I run the Peg Hole Registration , but I mostly use Peg Hole Registration function to register ROUGH animation drawings fed through a high-speed auto document feeder tray . For final line artwork that will be colored and composited over a background I scan the drawings one at time at high-resolution on a flatbed scanner , with the drawings on a peg bar . (this is still the most accurate way to keep the drawings in tight registration, although admittedly much slower than using the auto-feeder.)
It's a little weird. Could you send some examples, please ?
