join clip
join clip
When using TVP for storyboard I do all the panels in one clip. Afterwards I use the clip/splitclip option to separate the scenes. Is there an option to join them up again afterwards without having to open each TimeLine and copy/paste everything back together in the same timeline?
Re: join clip
Have you tried selecting "Render Camera to a new Project" under Project in the main menu bar?
Re: join clip
Nope, because it's problematic : how should we merge the different layers together ? Should we "merge" the layers from clip 2 after layers from clip 1 ? If so, what if there are 3 layers in clip 2 and only 1 layer in clip 1 ? What if all layers in clip 1 don't have the same duration ? Should we "cut / paste" layers from clip 2 above or below layers from clip 1 ?hilere wrote:When using TVP for storyboard I do all the panels in one clip. Afterwards I use the clip/splitclip option to separate the scenes. Is there an option to join them up again afterwards without having to open each TimeLine and copy/paste everything back together in the same timeline?
etc..
So, at the moment, you have to merge them manually.
Re: join clip
Hervé created a .tvpx to copy layers from next clip and paste them after the layers of current clip.
Go to the content sharing : http://www.tvpaint.com/forum/viewtopic.php?f=11&t=4723" onclick="window.open(this.href);return false;
