Go Go Wabbit Wainger
JM07
Post by JM07 »
http://www.youtube.com/watch?v=cpjwzc5Ib3Q
Youtube is butchering my video right now by dropping almost half of all the frames. It's really painful for me to watch. I do not recommend that people post their videos there before they post it to other forums. Does anyone have any recommended forums to post videos? I'd like to try this out again some place else.
This animation is actually almost fairly complete. All it needs is a few touch-ups. Enjoy.
Re: Go Go Wabbit Wainger
Can't watch, yt wants login.
Byron
Post by Byron »
Even when you're logged in - still says video is private! One or two boxes to tick on the Youtube, I think! :)
JM07
Post by JM07 »
It's not on private anymore. You should be able to view it.
http://www.youtube.com/watch?v=cpjwzc5Ib3Q" onclick="window.open(this.href);return false;
JM07
Post by JM07 »
Your comments appreciated whether positive or negative.
I couldn't make any sense of it, but some poses were nice.
I can't agree with you that your project is almost complete and all that it needs is a few touch ups; it needs lots of in betweens. If you can draw the key poses, you can draw the inbetweens, can't you?
JM07
Post by JM07 »
Paul Fierlinger wrote:I can't agree with you that your project is almost complete and all that it needs is a few touch ups; it needs lots of in betweens. If you can draw the key poses, you can draw the inbetweens, can't you?
I haven't learned all that as of yet. I found if I put too many drawings it looks robotic or too slow. Not sure as to how to do this yet.
ACTUALLY I TAKE BACK WHAT I HAVE WRITTEN HERE - ABOVE- AS I JUST FOUND OUT THAT YOUTUBE IS BUTCHERING MY VIDEO BY DROPPING FRAMES. DOES ANYONE RECOMMEND ANY OTHER FORUMS? THANKS FOR YOUR HELP.
Please, don't speak in Caps Lock, it's aggressive :)
You can try other video websites such as Vimeo.
Make sure you are encoding your video according to the guidelines recommended in the YouTube Help section:
YouTube recommended settings are:
H.264, MPEG-2 or MPEG-4 format
640x480 (SD) or 1280x720 (HD) for 4:3 & 16:9 aspect ratios.
Frame rate should be the same as original video
Sampling rate: 44.1KHz for MP3/AAC audio
See here for more info:
http://www.squidoo.com/youtuberight" onclick="window.open(this.href);return false;
Or look under YouTube's Help page (search for encoding or compression guidelines)
