greyscale RGB channels
malcooning
Post by malcooning »
Anyone has a suggestion how to view the RGB channels as separate greyscale images?
we used to have 3 button next to the 'preserve transparency" button. but since they are gone, anyone has a method?
cheers.
Re: greyscale RGB channels
try with the Color Factory tool. 8)
malcooning
True. forgot about this one.
That did it.
Cheers R.
a
P.S - do you know if color factory is scriptable? Will it be possible to create a script that duplicates the image 3 times, and then applying color factory to each layer, once with rrr values, then ggg and then bbb (separate RGB values to turn each layer to it's respective greyscale)?
malcooning wrote:... do you know if color factory is scriptable? ...
yes it is ! 8)
tv_plugin colorop cmd r g b a
