TVPaint and HDV
TVPaint and HDV
I'm ever hopeful that eventually I shall get my CBPaint with all the features of TVPaint. In the meantime I will continue to learn and experiment with my demo TVPaint, and it is very good.
I'm using it in conjunction with Vegas9 Platinum.
My question is, can I input an HD file? So far I have failed. I guess it has to be an uncompressed file so that I can overlay an animation on to a short clip. Is it possible, have I missed something in my experiments?
Alan
Alan
Re: TVPaint and HDV
How are you exporting the file from Vegas? What's the format or codec?
Re: TVPaint and HDV
The format is. 1440 x 1080 .m2t
I have no problem with .avi
Alan
Alan
Re: TVPaint and HDV
So what happens when you navigate to this file from Vegas to open project?
Re: TVPaint and HDV
It imports into Vegas and plays.
Only one frame imports into TVPaint via new and import footage, even though I choose a number of frames to import.
Re: TVPaint and HDV
I don't think you are doing it right. You should import the entire file as an AVI and a new layer. Wait, which version of TVP are you testing this on because I now wonder if it's at all possible to do this with a trial version -- someone else should respond to this issue.
Re: TVPaint and HDV
Successful import of video files all depends on video format and codec.
Re: TVPaint and HDV
Any MPEG works for me. Or QT Animation, which is uncompressed, as is Photo or Motion JPEG -- all uncompressed formats. Then import (open) the entire file in TVP.
Re: TVPaint and HDV
Hi Alan,
TVP should be ablle to import .m2t files.
However, please can you post a very short files, with a very few images inside ? We have no such files here to test the import properly.
- malcooning
Re: TVPaint and HDV
When I capture from my Canon camcorder into Vegas I get M2T files.
It's a good compression of HDV files, which allows for realtime editing (in Vegas anyhow), and also smooth playback in a media player.
TVP can import M2T, but not without problems. When I import M2T the responsiveness of TVP goes down, and often it just freezes.
Also, the progress indicator stays on 0% regardless of the progress.
So, we can deduct that it is buggy for the moment.
I'm attaching a 1 sec long m2t file.
- test.rar
- (3.59 MiB) Downloaded 1075 times
Asaf | asafagranat.com
Re: TVPaint and HDV
The same happened to me and I get only one frame to show on my timeline even though I can see more frames in the import preview, but I wonder why you have the sound track attached. Have you ever tried to detach the sound in Vegas before you export the clip?
Re: TVPaint and HDV
Thanks Asaf, we have made some tests.
It seems that TVP can not properly import .m2t at the moment.
Can you convert .m2t to .avi with Vegas ?
- malcooning
Re: TVPaint and HDV
sure. it's easy to do. just thought it's better to leave it on in this case for sake of testing.Paul Fierlinger wrote:Have you ever tried to detach the sound in Vegas before you export the clip?
It's no problem, that's the typical workaround. Just m2t is straight-from-camera and its compressor allows to play it back quite easily. most other HD encoders tend to be heavier to edit. but that's fine.Fabrice wrote:Can you convert .m2t to .avi with Vegas ?
Re: TVPaint and HDV
Asaf, I know how to split the sound track from the picture; I was just wondering why you didn't do it for the test.
As I was telling Alan, I thought he should just export a straight uncompressed avi but I don't know if he has that option in Vegas 9 Platinum, which is a consumer product. In Vegas Pro 9 the way to go is Video for Windows, Default Template -- which is uncompressed and which works fine in TVP.
Re: TVPaint and HDV
Thanks. The Platinum version will render as Video for windows, I'll have ago this evening.
Alan
Alan
