New Out of Peg feature
- donbartolo
Wow! I just read the newsletter!
That's great news!! Great thanks to the crew! I will try it out tonight! :p
Re: New Out of Peg feature
Hope you will like it =)
- Sierra Rose
New Light Table feature
I love, no-- make that LOVE LOVE that I can move my light table ghosts around!!! Thank you all so much for this terrific feature.
Edit: I meant for this to be it's own topic....somehow I clicked it wrong. Apologies.
WinXP 32bit 10.0.17Pro
I just fiddled around with it and it works great.
It's definitely going to come in handy for me in the future! Thanks!
- donbartolo
Hello zeu French Team!
I come back with some feedback!
First of all: really nice feature! Works just fine!
Some suggestions for a next update:
- is it possible to develop a 'lock' button for the out of peg changes?
=> A bad click on the lighttable will reset the out of pegs settings.
=> Sometimes you just want to disable the lighttable, and than go back into it later. But this also resets the Out of Peg settings.
- General : is it possible to put the transparency level of the actual frame at 0% while the other frames keep a transparency level higher than 0% ?
Exemple: -1=35% / 0= 0% / +1 = 30%
And not= -1=0% / 0= 0% / +1 = 0%
Regards,
Don B
Regards,
Don B
- LivieLightyear
Yes, the Off the Peg feature is wondeful! However, is there a way to draw in the frame while the frames are lined up "Off the pegs"?
"If you don't aim high, well, you're not gonna' get anywhere!" ~Milt Kahl
I really like this new feature.
In the lighttable, is there an option to keep a copy of frame A in position when you move off peg to draw B inbetween C? Rather than it completely moving off peg and no longer seen?
I would like to see both frame A and C aswell as a duplicate of A that I can move and scale.
Maybe I'm not using this new feature correctly?
hi Ben,BenEcosse wrote:I really like this new feature.
afaik, it's not possible to see the same key "in-peg" and "off-peg" displayed at the same time,
but as workaround, you can duplicate the key first, off-peg the duplicated one, and use the LT to see both, then, once the inbetween done, reset the off-peg and delete the duplicated item.
for the time being, my way is to use the flip-book button to temporarily "re-peg" the off-pegs and scrub going backward/forward by LMB-drag.
good workround, thanks.
Do you know if you can transform the Off Peg frame without the ratio staying the same?
