Big drawing lag on imac
Yesterday the new schoolyear started and i have a classroom with 16 imacs running TVP animation 9.0 that al lag with drawing.
a fast circle results in a half circle because the beginning of the line is straight. hetching a row of lines results in only a few dots because most strokes don't even register.
its the biggest lag i've ever seen in tvp
we also get a lot of those spinning rainbow umbrellas between actions.
the cache is set to automatic (as it should right?)
in another thread Hervé asked for the proxy setting; the datarate is 20MB/s while the machine computes at 57 MB/s
specs:
Model Name: iMac
Model Identifier: iMac7,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 800 MHz
System Version: Mac OS X 10.5.8 (9L30)
Kernel Version: Darwin 9.8.0
Boot Volume: Untitled
Boot Mode: Normal
Computer Name: Media Intel (71)
User Name: Student (student)
Time since boot: 1 day1:54
Wacom : CTE 440
Hervé
Re: Big drawing lag on imac
Post by Hervé »
Try to set the proxy to "RealTime".
Hervé ADAM, TVPaint Team
Help i'm now in class
i don't have the real time option!
only:
Proxy
No proxy
render
Hervé
Post by Hervé »
Peter Wassink wrote:Help i'm now in class
only:
Proxy
No proxy
render
No Proxy
elmisilhumano
Post by elmisilhumano »
What are the advantages of the three different proxys?
M.
Mikko Vormala
only:
Proxy
No proxy
render
No Proxy
i tried that but no difference, all three options exactly the same drawing error..... help
Hervé
Post by Hervé »
1: install the update
2: look in the activity monitor if no other process use the cpu time
3: look in the activity monitor if no other process access the disk
4: look in the preference panel where is the temp file
5: look is there is free space on this disk
6: check in the problem appear on other software
[edit]
7: Check the wacom drivers ( and the USB port )
8: Set openGL off ( OSX Only, in the preference panel )
elmisilhumano
Set open GL off
Mikko Vormala
Hervé
Post by Hervé »
elmisilhumano wrote:What are the advantages of the three different proxys?
M.
There is only one proxy with different settings:
-inactive ( build the display in realtime during the playback )
-render in a background task ( load proxy image during the playback )
-render before playing ( render all proxy images before the playback )
Hervé
Post by Hervé »
elmisilhumano wrote:Check the wacom drivers
Set open GL off
Good point !
elmisilhumano
M.
But I don't know what is best to use? Which one uses most of the memory? Is some better with the short clips some better with the bigger projects?
My mac have a lot of memory and speed but sometimes my mac with tvp still get slow with bigger projects.
M.
Mikko Vormala
Set open GL off
Good point !
how to do it on a mac?
can't find it :(
Hervé
Post by Hervé »
Set open GL off
Good point !
can't find it :(
in the preference panel ( only with the OSX version of TVPA )
i'll try all options from the list.. (not easy for me on a mac :roll: )
1
i downloaded 9.5 (cool that its also ready for standard!)
2&3 cant find the activity monitor
edit; found it and it seems to work fine
4
/tmp/ ?
5
200+ GB
6
in photoshop no problem
7
the wacom drivers is version
5.1.1-1
2002-2009 its the latest
8
and it had an openGL function but is was off
still
the problem persists
So nothing works alas :(
we also tried it with an intuos3...but same problem:
the beginning of the line is not registered, but once drawing starts it draws as normal
Roderique the HKU system manager suggested that it might have to to with the graphics card?
i hope a solution can be found before next weeks lesson
Roderique can test your suggestions on Monday and Tuesday, i am only here on Friday morning.
4 circles, nr 4 is what happens if you continue drawing... it works as normal
Picture 1.png (26.37 KiB) Viewed 22375 times
graphics card info:
Picture 2.png (36.91 KiB) Viewed 22373 times
