Undo spline points?
Posted: 21 Aug 2009, 15:42
by KenC
Is there anyway you can undo spline points?
They don't seem to go into the undo history so if I draw a couple nodes and then want to undo, I'm undoing stuff I drew before starting to draw the spline and not the points. Selecting a node and hitting the delete key doesn't do anything either.
Also while on the subject of splines.. when adding a point somewhere along a path (Context click/add point) it doesn't show up until I click the new (invisible) point. However, if I recall a spline I created with "Enter" and add points, then they show up like they should, seems like a small bug.
Re: Undo spline points?
Posted: 21 Aug 2009, 15:47
by Fabrice
Ok bug confirmed. :)
Posted: 21 Aug 2009, 15:51
by ZigOtto
KenC wrote:... Selecting a node and hitting the delete key doesn't do anything either.
to delete a point on a Bezier spline, select it and RMB-Click (on the selected point)/Delete Point,
(the top one of the 5 commands of the popup menu).
Posted: 21 Aug 2009, 16:49
by KenC
Fabrice wrote:Ok bug confirmed. :)
Yay, found my first bug :)
ZigOtto wrote:to delete a point on a Bezier spline, select it and RMB-Click (on the selected point)/Delete Point,
I was hoping to avoid that, it's very slow to rmb-delete on a lot of points, would be easier if delete just deleted the selected point and then selected the previous one. Then you could quickly hit delete a couple times to chop of points until you got to where you wanted to continue from, or if points were added to the undo history you could just hit undo a couple times.
Posted: 21 Aug 2009, 19:08
by Patrice
Understand by "Bug confirmed" that it will be fixed in the next update :wink:
Posted: 24 Aug 2009, 06:49
KenC wrote:I was hoping to avoid that, it's very slow to rmb-delete on a lot of points, would be easier if delete just deleted the selected point and then selected the previous one. Then you could quickly hit delete a couple times to chop of points until you got to where you wanted to continue from, or if points were added to the undo history you could just hit undo a couple times.
Soon you'll be able to delete last points on a spline when using "Shift-Delete" on your keyboard :wink:
Posted: 24 Aug 2009, 09:28
by KenC
Great, thanks :)
Can't wait to see the next version.
Posted: 24 Aug 2009, 09:38
KenC wrote:Can't wait to see the next version.
Me too :mrgreen: (I mean, I can't wait to loudly proclaim : "heeey ! TVP 9.5 is now available !!!" =D)
Posted: 24 Aug 2009, 19:40
by Patrice
it will be a great day! because it will mean that TVP10 development will start :wink:
Posted: 13 Sep 2009, 10:35
by KenC
Did this make it into 9.5? I can't make it work. I searched in keyboard shortcuts in case I rebound that key (Loaded my saved shortcuts from last version) but there doesn't seem to be anything that will undo spline points.
Posted: 13 Sep 2009, 13:55
by malcooning
KenC wrote:Did this make it into 9.5? I can't make it work. I searched in keyboard shortcuts in case I rebound that key (Loaded my saved shortcuts from last version) but there doesn't seem to be anything that will undo spline points.
you're right, it has been left out of the update. No Undo and no delete-point shortcuts of yet. Only the more laborious right-click to our salvation.
Posted: 14 Sep 2009, 08:13
It works men, just set the default keyboard shortcuts, and all will be okay =)
If you don't want to have the default shortcuts, please, put a shortcut on "Drawing : delete the last point" =)
Posted: 14 Sep 2009, 09:11
by KenC
"Drawing : delete the last point" aha!
I was searhcing in the shortcuts for "undo" and also couldn't find anything just scrolling the list looking for something that looked like it would undo spline points. I get snowblind sometimes looking though that huge list :)
Posted: 14 Sep 2009, 09:44
No problem KenC =)
