Drawing Recorder transparent bg?
- Klaus Hoefs
Is it possible to have transparent background for layers made with the Drawing Recorder (- or do I have to color-keying them later...
Re: Drawing Recorder transparent bg?
Yes, the recorder keep what you see, if you draw on a transparent project ( background set to none ), the recorded layer background will be transparent.Klaus Hoefs wrote:Is it possible to have transparent background for layers made with the Drawing Recorder (- or do I have to color-keying them later...) ????
Hervé ADAM, TVPaint Team
- Klaus Hoefs
Thank you very much Herve !!
Yes it works.
But anyway my transparent project bg color if set to "none" shows a black visible color - not very comfortable to draw! (but exports transparent just as expected !) - Is there a way to set this to white (and to have "none" for export) ?
Yes it works.
Couldn't you draw on white and then do the undo/redo thing on None?
No, sorry.Klaus Hoefs wrote: But anyway my transparent project bg color if set to "none" shows a black visible color - not very comfortable to draw! (but exports transparent just as expected !) - Is there a way to set this to white (and to have "none" for export) ?
- Klaus Hoefs
No this didN#t ( - or made it the wrong way...) - I think because a film with all visible information (drawing + bg) is recorded and it can't be changed.
- Klaus Hoefs
ok, thanks for swift replies -- I'll try it with color-keying.
