expanded sketch panel with red green etc.
I knew I had this panel once (believe it was built in) but can't seem to find it anymore. Is it downloadable?
Re: expanded sketch panel with red green etc.
I thought too it was inbuilt as one of the 3 versions of the sketch-panel,
look into your plugins folder, don't you have a SketchPanelRGB. bin file and a SketchPanelRGB.data folder ?
btw, which version of tvpa do you have ? or ar you still a miragist ?
Hi Zigotto, the file you mentioned doesn't seem to be in the Plugin folder...
I have TVP 8.6.
I have TVP 8.6.
weird, ... have you tried to create a new config at start ? ( I think it should be there in the default config )
or try to update (or uninstall /re-install) to make it re-appear .
if you had it for a time, it should come out again, by a way or another ...
I am gonna do a reinstall of the entire program and its components, so I hope it just returns, because it is a damned handy panel.
blast, I removed and then reinstalled the program but the settings apparently were still the same (same custombrushes and settings i had saved).
So I resetted the configuration but still no sketch panel with red and green etc. Is it possible that someone uploads that folder and that I download it and drag it in the plugin folder so that its back? I'd very much apreciate that!
well, as it's copyrighted, I think only one of the tvpaint band can do that here ...
... Elodie ?
... Fabrice ?
eventually, try to PM to one of them.
... Elodie ?
... Fabrice ?
Red green blue Sketch panel is not available for TVPaint 8, sorryBoomslang wrote:Hi Zigotto, the file you mentioned doesn't seem to be in the Plugin folder...
I have TVP 8.6.
Hervé ADAM, TVPaint Team
Hm. Too bad.
Weird. Maybe it was in a TVP 9 trial then that I had that panel.
Well whaddayaknow. You can import the RGBsketch panel from the TV9 into TVP8 and it works, albeit that the order is a bit messed up and the fill tools don't work either..
