Can't Modify Project Size
Inkyjellys
Post by Inkyjellys »
Hiya,
So I recent found a bug in TVPaint (12.0.5) where every time I click on the 'Modify Project' tab it just greys out my screen, leaving my screen unworkable. I found this out since I was trying to rescale a project I was working on for a client.
Is there anyway it could be fixed?.
I linked a video down below.
Thanks,
Inkyjellys
Evidence.mp4
(7.72 MiB) Downloaded 7 times
Re: Can't Modify Project Size
TVPaint is likely hiding the "modify project panel" somewhere.
This kind of mysteriously hiding panels behaviour is new since v12 allows floating panels.
i don't think there is a fix.
though maybe creating a new config helps...
The window must be appearing somewhere on the edge of the screen.
Do you use multiple screens? Are they configured in a particular way?
Inkyjellys
Dean wrote: 30 Jun 2025, 07:44 The window must be appearing somewhere on the edge of the screen.
Hiyaa,
While i usually use multiple screens, in the video above I was just using one screen. This issue also persists when i use multiple screens as well.
Inkyjellys
Peter Wassink wrote: 29 Jun 2025, 20:17 TVPaint is likely hiding the "modify project panel" somewhere.
Hiyaa,
Do you mean like changing my default layout configuration in TVPAINT?.
