After using Transform Position or Shape, how do I get rid of the bounding box?
BruceM
Post by BruceM »
After I've used Shape: Transform Position or Shape: Perspective to change my drawing, I'm using a shortcut combo of Shape: Apply and Shape: Select Clear, but the green or red bounding box doesn't go away. What additional command do I need to use to have the box go away?
Thanks
Re: After using Transform Position or Shape, how do I get rid of the bounding box?
That's because you've still got that tool selected. The rectangle stays unless you choose another tool.
BruceM
Post by BruceM »
I added the shortcut "Get Previous Tool", and it works perfectly now.
Thank you so much Slowtiger!
