TVPaint 11.7.5 can't delete multiple selected layers
ChristopherC
Post by ChristopherC »
Hello, i've noticed that multiple layers can't be deleted at the same time like in previous versions. (shift clicking layers to select multiple then 'right click > delete' does nothing). (On MacOS latest version)
Re: TVPaint 11.7.5 can't delete multiple selected layers
Confirmed on my end. ( TVPaint 11.7.5 running on MacOS 12.7.1 Monterey)
Confirmed on my end on Windows, the delete key still works.
EDIT: the bug has been fixed on our end, new builds will be generated soon.
Dean wrote: 15 Apr 2025, 07:19 EDIT: the bug has been fixed on our end, new builds will be generated soon.
About new builds with fixes for 11.7.5: I just want to add that with 11.7.5 I have been experiencing frequent random crashes. Now, to qualify that report , I will say that the pixel resolution of those projects which tend to crash frequently is 6K , however I have worked at 6K resolution in previous versions of 11.7 and not had the frequent random crashes. I can't pin it down to anything specific that causes the crashes. It's just a general observation that it seems to me that 11.7.5 crashes more frequently than 11.7.3 which was the version that seemed the most stable and that I used the longest. I am still using 11.7 instead of 12 because I have collaborators who are still using 11.7, so it just avoids any version conflicts for me to stay on 11.7. However, I am switching back to 11.7.3 because 11.7.5 seems to me to be too unstable, at least at the higher 6K resolution I'm working at. 11.7.5 may be very stable at 4K or 2K , but I imagine I'm not the only one who needs to work at higher 6K or 8K occasionally --- for example, in the case of extreme camera zooms from a wide field to a very tight field -- so it would be desirable to have 11.7.5 have more robust stability at higher resolutions.
Hironori Takagi
Post by Hironori Takagi »
We have received the same feedback from our studio staff. Is this issue addressed in the latest build (Windows)?
In TVPaint11.7.5/Windows, right-clicking and deleting multiple layers is no longer possible
Hironori Takagi wrote: 24 Apr 2025, 08:21We have received the same feedback from our studio staff. Is this issue addressed in the latest build (Windows)?
Yes, I've finished uploading the builds, if you download from the website it should be fine now.
