can't find fx stack window Topic is solved
shaniartist
Post by shaniartist »
i'm really new to tvpaint- using version 12, and I'm trying to use the keyframer tool. When watching some tutorials on youtube I saw them open the fx stack window, but no matter what I try i'm not seeing this window pop up.. when i press the open/close fx panel it shows/writes what i'm doing on the layer but there is no window. what am I doing wrong? :(
thankss!!
Re: can't find fx stack window
Hello, could you try enabling the FX panel and then lowering your main TVPaint window? It might have slipped under. This can occur sometimes if a change of settings occurs one on of your screens of if you use multiple screens which have very different resolutions.
shaniartist
Dean wrote: 07 Apr 2025, 12:05 Hello, could you try enablind the FX panel and then lowering your main TVPaint window? It might have slipped under. This can occur sometimes if a change of settings occurs one on of your screens of if you use multiple screens ahve very different resolutions.
thank you! that solved it
