12.0.3 Right Click Erase while hovering bug Topic is solved
kelanhordos
Post by kelanhordos »
Just taking 12.0.3 for a test run and noticed when you are hovering over a drawing with your stylus(no contact on the tablet screen) and do a right click it erases a single brush stamp where you are currently hovering. Previously in older versions you need to actually press down with the stylus to start erasing.
I imagine this is related to the patch note
[WACOM TABLETS] Hover click mode now works in Wintab + Subpixel mode
and maybe its intended behaviour, if so is there a way to disable it?
edit: Nevermind, I jumped the gun and see this is an option under Wacom properties, I didnt realize it before since it wasn't working I guess. Leaving this up in case anyone else has the issue and is wondering. You need to set Wacom Advanced settings Pen button mode to Click & Tap instead of Hover Click.
Tvpaint 12.0.1 Pro
