lagging brush after add custom brushes
skeh
Post by skeh »
Hi
I'm using on tvp 11.7.4
currently i've added custom brushes through this forum
wild oil.tvpx and San_tools_BrushEraser
suddenly normal brushes has too slow and makes gap at point
even in document size is down to 480p
so i removed them on panel bar
as well as removed and installed tvp again
it still speed is slow
photoshop is great working
on m1 air
m1 air
with cintiq pro 27, movink
tvpaint pro 11 on mac
Re: lagging brush after add custom brushes
skeh wrote: 08 Dec 2024, 07:58 suddenly normal brushes has too slow and makes gap at point
Hello, do you have a particular line smoothing setting enabled in TVPaint?
Also, does hitting "reset" on one of the default brushes make them act normal again?
skeh
Post by skeh »
Dean wrote: 09 Dec 2024, 08:37
thanks for reply message
simply i deleted all tvpaint with config settings
after that i reinstalled it again
it almost recovered as first
m1 air
So the normal brush performance didn't come back?
Did you reset your TVPaint by deleting its configuration file in the Libray folder or via the Startup Panel or simply by deleting custom items from within TVPaint?
