Sonoma and V12pro Topic is solved
Simon W Edmondson
Sonoma and V12pro
Post by Simon W Edmondson »
Having some problems with V12pro crashing.
It has been fairly stable up until the past few days, when it has suddenly cut out to the desktop. Circumstances different each time, until today.
A couple of times it happened just after saving, once or twice, when drawing with the pen tool. Today, while trying to add a straight line, it cut out three times in a row within 10mins.
Trying to draw over the top of some pre rendered png frames.
Is this a common occurrence ?
simon
Mac Studio Ulta M2, 64gb, OSX sonoma
Cintiq 16HD
Re: Sonoma and V12pro
Hello Simon, which version of V12 Pro are you currently using?
Simon W Edmondson
Thank you for your reply.
It's version 12.01 and OSX 14.7.
There was a lot of bother getting it setup which your colleague Matthieu resolved .
simon
Can you update to v12.0.2? We've fixed a lot of crashes on macOS on this version.
Absent until May 12th.
Simon W Edmondson
Thierry.
Thank you for your reply.I shall try that this evening. It has been a bit frustrating to have it cut out, seemingly at random
simon
Simon W Edmondson
Thierry.
My V12 pro is installed on a Mac studio as previously mentioned. When I try to log in to the TVP site on that computer. The request is denied, even using the same info as used to log in here, now, using an Imac on the same table as the Studio. Is there a problem ?
regards
Simon
Hello Simon, no issue with our website has been reported recently. Did you try logging in from a different browser?
Simon W Edmondson
My apologies. I tried again. ten minutes later, using the same details, and it worked!
Update is now duly installed and hope to finish current project this afternoon., ( fingers rossed ).
regards
simon
