Here's a bug I noticed in moving projects from v12 to 11.7.3 -
If I create a project in version 12 which has CTG layers , then I share that project with another team member who is still using version 11.7.3 , when they open the project in 11.7.3 the CTG layers are disabled and no source is assigned to the CTG layers. It can be fixed by simply re-assigning each CTG layer to it's proper source layer , but if there are many layers that is quite time consuming ... and even if it is only two or three layers it still should not happen.
CTG Layers disabled when opening v12 project in v11.7.3 [TVPA-3682]
Re: CTG Layers disabled when opening v12 project in v11.7.3 [TVPA-3682]
Hello David,
We managed to reproduce your issue, our devs will look at it as soon as possible [TVPA-3682]
Léo Fernandez
Wacom driver version 6.4.2-3
