TVP Exports fps at double the speed Topic is solved
mikdog
Post by mikdog »
Super weird, my project is set to 24fps but when I export a movie from TVP, it goes super fast and the video is half the length, though the audio is the correct speed. Obviously pic to audio goes out of sync quickly. I need to set the export to 12fps to get the correct speed, but then my camera moves are stuttery.
Any tips here please? I've tried with 1:1 settings, with half size, with MP4 and MOVs.
Re: TVP Exports fps at double the speed
Hello, which video player do you use?
Could you send me a link to this exported project via PM, please?
mikdog
Post by mikdog »
Dean wrote: 24 May 2024, 09:15 Hello, which video player do you use?
Thanks Dean. I've tested on Quicktime, VLC and Infuse, all with the same results.
Will DM you the normal (fast) export as well as the 12fps export, thanks
mikdog
Post by mikdog »
Thank you to Dean who very kindly had a look at my project file and identified the issue - it was the Camera Parameters which were set to 12fps. Changing that to 24fps solved the problem. Shew, dunno if I would have found that myself.
Hm, interesting. I wonder how much sense it makes, anyway, to allow camera FPS to override project FPS?
