why does it repeat last drawing/frame
when i draw on new frame ,last drawing also appears..how to stop this?
Re: why does it repeat last drawing/frame
You are are drawing on a new frame but not on a new drawing.
if you want a new drawing you should first clear the frame.
if you want a layer filled with a range of empty frames, select all frames (double click or drag under the layer) and press clear (skull and bones button in the main panel)
i know about skull and bones button and i did use it before making new empty frames..but is not there any fast method to make empty frame ?Peter Wassink wrote: ↑26 Mar 2024, 20:18 You are are drawing on a new frame but not on a new drawing.
Wow....Version 10.0.16? The notorious cracked (pirated/stolen) version of TVPaint 10...
TVPaint 12.0.0 Pro
Ah yes, best to first update to v10.5.7
its free.
Just switch off "Hold" in the first frame (the little pulldown right from the frame).
Right!
Well, I was thinking that someone using a version that old would be familiar with the basic functionality and be able to resolve this very simple issue on their own. This suggests that they're actually new to the software. Anyone new to the software would surely be on version 11 though I think.
But hey, I'm gonna take off my Columbo hat and see my way out!
TVPaint 12.0.0 Pro
Locking this topic.
We do not provide support for cracked versions of the software.
Absent until May 12th.
