Export failing
garthlaidlaw
Export failing
Post by garthlaidlaw »
Hi there,
I'm having an export error, what does this mean?
Error avio_open: 1367088
Thanks for the help.
Garth
Re: Export failing
Hello Garth, which TVPaint 11 version are you currently using? It can be found in the "Help > About TVPaint" window.
It seems like your TVPaint's configuration needs to be reset.
First, you can export your custom settings: https://www.tvpaint.com/doc/tvp11/index ... m-settings
Keep CTRL pressed when launching TVPaint from the desktop shortcut. The Startup Panel will appear, you can use it to create a new config file, then launch TVPaint.
If it doesn't work, press Windows + R and write %appdata% in the field, then press Enter, then in the new window, look for the TVPaint folder, then inside the "default" folder, delete the config.ini file to reset TVPaint's configuration.
