Poly selection tool Topic is solved
Poly selection tool
In Photoshop, while using the poly selection lasso tool, you can hit delete to undo a point. Is there a shortcut for this in TVP using the poly lasso tool?
Re: Poly selection tool
no
I never knew that about the Poly selection tool in Photoshop (thanks , now I know !)
That would be useful in TVPaint , too.
The only workaround for now would be to use the Bezier or B-Spline Selection tools which have the menu option for Deleting a point when you right-click on the point.
or simply paint the selection you need with any drawing tool and use the magic want tool on that to transform the area to a selection...
but you may not even need the selection at all.
if you use the layer with the painted selection as a stencil
