Background > None, Colour and Check
daninski
Post by daninski »
Hi,
Is there anyway to have the background colour separate from the colours involved in the check? I'd like a white background layer, but for Check background I'd like a light grey and a mid grey. Which is currently not possible. IF I could change the colour of None to white, from black, that would solve my issue but I can't find that as an option.
Is it possible?
If not... FEATURE REQUEEEEEEST!!!! ;)
Thanks.
http://www.daninski.com
NathanOtano
Re: Background > None, Colour and Check
Post by NathanOtano »
Can't you just switch your background colors (bottom left of layer panel) between flat color and 2 colors and with the color you'd like to see? I'm not sure if I understood your request correctly
daninski
Post by daninski »
The Colour background is linked to the one colour of the checked. So if flat colour is A, then check is A and B. I'd like flat colour to be A, and checked colour to be B and C...
Animationriver
Post by Animationriver »
:D
daninski
Post by daninski »
Nope, It's still black when I check Background to •none. I'm talking about the background toggle at the bottle left of the clip timeline.
none = black.
background.mov
(1.6 MiB) Downloaded 1692 times
daninski
Post by daninski »
So you can see my problem in your video Elodie. I don't want my Check colours linked to the Colour one. Do you understand what I mean?
I understand and like to have the same options:
Black
White
Transparent/Checkers (made from 2 colours which are NOT linked to white)
tv_BackGround
parse result Bkgnd
IF CMP(Bkgnd,"check 128 128 128 200 200 200") = = 1
tv_BackGround "color" 200 200 200
ELSE
tv_BackGround "check" 128 128 128 200 200 200
END
Here's a quick solution I use all the time: ToggleBackgroundButtons.tvpx. The first button has a GEORGE script that toggles between White, 3 shades of Gray and Black background, plus a light Gray checked background. The second button has an embedded script (as listed above) in which you can change the individual RGB settings yourself.
[edited Jan 17 2018]
And here is the other, longer script which can also be edited (just remember to follow the logic on RGB values that are changed and make sure they are the same in the IF test that follows). Click Select All and EMBED in place of the above script and you'll have White, three shades of gray and black plus the check background.
Param none
ScriptName = "ToggleBackgrounds"
tv_BackGround
parse result Bkgnd
	tv_BackGround "color" 255 255 255				// white background
	EXIT
END
IF CMP(Bkgnd,"color 255 255 255")
	tv_BackGround "color" 200 200 200				// light gray background
	EXIT
END
IF CMP(Bkgnd,"color 200 200 200")
	tv_BackGround "color" 120 120 120				// medium gray background
	EXIT
END
IF CMP(Bkgnd,"color 120 120 120")
	tv_BackGround "color" 60 60 60					// dark gray background
	EXIT
END
IF CMP(Bkgnd,"color 60 60 60")
	tv_BackGround "color" 1 1 1						// black background
	EXIT
END
IF CMP(Bkgnd,"color 1 1 1")
	tv_BackGround "check" 128 128 128 200 200 200	// checkered medium gray and light gray
	EXIT
END
tv_BackGround "color" 255 255 255					// if any other background, then display white
(165.5 KiB) Downloaded 1376 times
NathanOtano
Scripts are always a solution hehe <3 love tvpaint
daninski
Post by daninski »
Svengali wrote: 16 Jan 2018, 15:33
tv_BackGround
parse result Bkgnd
ELSE
END
Thanks Sven! I changed colour to 255,255,255 and I'm running :) I'll keyboard shortcut to it asap! :)
