Rename layers
Rename layers
Hello there,
Here is two small scripts I've made to rename your layers.
Both rename the layers with the following pattern :
  • The layers are renamed from bottom to top (i.e. first layer to be renamed is the last one on the layer list). If needed, I will make another script that will rename from top to bottom.
  • The names are as follows : A,B,C...,Z,ZA,ZB,...,ZZ,ZZA,ZZB...,ZZZ.
  • Up to 77 layers can be renamed.
One script renames the visible layers, and the other one renames layers that are unlocked.
Rename_Layers_visible.tvpx
(7 KiB) Downloaded 429 times
Rername_Layers_lock.tvpx
(7 KiB) Downloaded 436 times
Si votre question a trouvé réponse, marquez votre sujet comme Résolu.
If your question has been answered, mark your topic as Solved.
GeorgeHarris76
Re: Rename layers
Post by GeorgeHarris76 »
Thierry wrote:Hello there,
Hey there!
Thanks a lot for sharing! I've been looking for something like that? Has anyone already tested them?
I'm gonna try it later this week, I'll let you know!
yalih
Re: Rename layers
Post by yalih »
hey! I tried it and it works
the only thing is that I was hoping for a script that will make it possible to add a prefix to all layers before the original name
is it possible to create something like that?
thanks
yali
[vimeo]https://vimeo.com/yali[/vimeo]
