Share your Interface Look!
- schwarzgrau
Re: Share your Interface Look!
No I'm still waiting for the Paypal-link. I just removed the "Purchase" button in my screenshot.
Ah, thanks.
This is quite interesting; for instance I never realized that 100% black would work so well for the sound wave or the cursor on the Project panel. I'm going to try wearing this for awhile, but the only item I had to change was "Background Current" only because it's necessary for me to instantly recognize which layer is currently active. But otherwise I find the dark simplicity surprisingly easy to negotiate through. Thanks for sharing.
- schwarzgrau
You're welcome Paul. Oh and you're right I changed background-current to give it a bit more contrast.
What did you change it to? Perhaps you could just give us the RGB numbers.
- schwarzgrau
I changed "Background current" to the very dark grey, which is nearly black.
R 46
G 46
B 46
But I updated the *.ini in my previous post too.
R 46
G 46
B 46
Very nice; you are good at this. What do you think of the active and inactive buttons that used to be red and green and also the activated lightable which had a brighter flare? I ask because for the same reason as the Background Current, I need to see at a glance which layers are turned off. I actually had to reinstall these buttons from the old versions.
- schwarzgrau
Thank you Paul. I'm with you on this. I really like simplicity and if everything is so settle as possible, but at the moment I need a bit longer to see if a layer is activated or not. That's really something you should see immediately
Here they are (courtesy of Peter Wassink) if you'll find you need them back.
All you have to do is drop them into both the "light" and "dark" folders inside the "icon" folder and click "replace all").
A small hassle is that you have to do this with each new installment.
- schwarzgrau
thank you
Sorry for the delay guys, you will have your links and invoices tomorrowSewie wrote:So did you receive the downloadlinks for TVP11?
Cause it looks like you are working with it.
- schwarzgrau
Hey Paul,
I modified the original DIP-files of the layer-on and off indicators, from the demo of TVPaint 11 and packed them in this ZIP. So the size and the design fits the new layout.
Thanks, Mark
Will take a look right away; I'm actually very curious to find out how you designed them.
- schwarzgrau
It's nothing special, just a red and green coloured circle with a tiny bit of gradient.
You're correct; not that different yet makes a difference in the over all effect your GUI design projects. After working with these for some time now, I find yours the most comfortable one I've ever used, though I will understand if a newcomer to TVPaint will find it to difficult to find certain items if they don't know yet exactly what it will look like once they find it. Thanks for sharing again.
