Eraser size
Re: Eraser size
Elodie wrote:Actually, when you are using the "Eraser" function from Wacom, you are using the "Swap Stylus Tip" function in TVPaint (like if you were using the other tip on your stylus).
We noticed a bug when you use Swap Stylus Tip : it does not remind the configuration of your second tip each time you restart TVPaint. By default, it's a pen brush with size = 5. So even if you configure it as an Oil brush with size = 50, when you restart TVPaint, the Pen brush is back again.
It's in our "to fix list" :)
fixed, wait for next version. :)
Re: Eraser size
I wanted to add one comment to the thread. I use a different method for eraser in part because I want to save the current "draw smoothing" setting for the tool when I call the eraser so that the "draw smoothing" for the eraser can be set to zero for more precise control. When I return to the previous tool, I want the "draw smoothing" restored (along with all other tool parameters.)
I was wondering if the next version update will manage this same "draw smoothing" control for the eraser and the temporarily swapped tool?
A discussion on tool parameters including the issue of "draw smoothing" control can be found HERE.
Re: Eraser size
That's an interesting point you have here.
Thank you for reminding us this !
