TVPaint Animation 11 changelogs (latest update 2025_03_26)
Re: TVPaint Animation 11 changelogs (latest update 2024_03_26)
Hello everyone,
As explained on the TVPaint 12.0.2 changelog, we have also released TVPaint 11.7.4, that addresses the following issue:
  • [macOS] Fixed the random crashes that were happening on the ARM Macs (M1/M2/M3 and future versions).
We also made it so if you only have a v12 license activated, v11.7.4 will use the v12 license to run.
Re: TVPaint Animation 11 changelogs (latest update 2025_03_26)
Hello everyone,
We have released TVPaint Animation 11.7.5.
We've decided to implement some fixes and improvements that have been made in v12 that v11 users could definitely benefit from before they can upgrade to v12.
Also, please note that unless some major issue is found, this should be the final v11 update before we end v11 support later down this year.
What has been fixed and/or improved in TVPaint Animation 11.7.5?
Timeline
  • Image Marks from projects saved in v12 no longer open on the wrong layer in v11.
  • Reorganized layer's right-click menu to make it close to v12's one.
  • Layer transparency level is now displayed even if the layer is locked.
  • Fixed a bug that could place new instances created on CTG to be at the wrong place.
  • Timeline can once again be scrolled in Project View after pausing playback.
  • The last layer's Blending mode can now be changed again.
  • Project Tab → Timeline View no longer cuts frames when too many frames are present on a clip.
George:
  • tv_SaveDisplay now saves DPI information.
General
  • Update pop-up will now correctly remember your choice of not showing up again.
  • [WACOM TABLETS] Hover click mode now works in Wintab + Subpixel mode
  • Horizontal lines should no longer appear out of nowhere when drawing.
  • Save Alarm's "Warn Me" mode is now active even if the project has not been saved yet.
  • Added an Antialiasing selection drop-down menu for Crop Tool.
  • Using Paint Bucket when the current layer is using Multiply Mode no longer causes unusual results.
  • When exporting from Clip: Display, the original name is kept during export.
  • Project DPI no longer changes when loading images and/or projects.
  • Playback button allows previewing the FX stack once again.
  • DPI value is no longer reset when a project is cropped.
  • TIFF exports, TIFF imports and PSD imports now include DPI information.
macOS
  • TVPaint 11 now opens on Low-Resolution mode.
Locked
