Hello, the Asus stylus might work differently from what we are used to, since the Wintab tinkering seems to help with every major tablet brand.
I guess using the stylus' driver to make the button "emulate" the right click could help?
TVPaint and Windows 11
Re: TVPaint and Windows 11
- NathanOtano
There is no driver for the Asus pen :'(
I maybe should try another brand with my laptop
Thanks for your help, I'll continue searching then
- NathanOtano
Quick post I found, may help some people using Ink I don't know : https://www.reddit.com/r/Windowsink/com ... indows_10/
Still searching for my pb
i have the same problem!
with ink i have pressure but not the right click
and with wintab i do not have pressure
any way to solve it?
[vimeo]https://vimeo.com/yali[/vimeo]
Hello Yalih, does ticking the "Subpixel" square in Wintab mode improve things? If not, this might be a driver issue. Maybe try to create a dedicated TVPaint profile on your tablet's driver if it allows you to do so.
This might also be linked to a "hover click" setting inside the driver.
I'm using tvpaint with window 11 too and it's working good.
For what it's worth, I've been wrestling with this for hours. Finally I rolled back to the previous driver (1/25/2024), then turned off windows ink ( select the pen in wacom center then the calibrate tab, untick box at bottom) the turn subpixel off in tvp (edit/preferences/general, under wintab). Seems to have fixed it. Same process did not work with the current driver. I'm using Windows 10.
