Exported files in recent files
A forum where you can suggest which features can be deleted or merged with other options.
NathanOtano
Post by NathanOtano »
Hey,
I don't like the fact that newly exported files are put in the "recent files" menu. I usually only need the files I opened with TVPaint and the exported files confuses me to find the file I need to open :)
Nathan
Re: Exported files in recent files
schwarzgrau
Post by schwarzgrau »
+1 from me too
agreed, maybe a new item recently exported would make sense ?
or perhaps place this in the export panel.
Peter Wassink wrote:agreed, maybe a new item recently exported would make sense ?
Yes, a drop down or pop up list of Recently Exported files in the Export panel makes sense.
The listing of recently created and saved files is stored to and retrieved from the config.ini file each time TVPaint is quit or started.
I had the same negative reaction as Nathan, et al., to the different file types that fill up the list, so I wrote a utility last year that lets me choose from recently saved .tvpp files (only) which I upload here. I should note that the "TVPList" utility also attempts to filter out any path/.tvpp files that can no longer be found or loaded, unlike the Recent files listing.
Myself, I'd like to have a Preference checkbox that would offer the option to build and display a chronological list of saved TVPP files only.
TVPList.tvpx
updated Dec 4, 2016
(83.5 KiB) Downloaded 3495 times
NathanOtano
I wasn't aware you can do that <3 thanks for sharing sven
Update: Found a silly bug in the TVPList utility: the loading loop skips the most recently saved file. :oops:
I've updated the original TVPLIST.TVPX download file...
If you are using it, please download again and reinstall.
NathanOtano
Thanks! :)
