break instruction
fazek
break instruction
Post by fazek »
I've tried to use the break keyword inside of loops and it seems break cannot abort the loop conditionally. I think it's because the if..end is also a code block for the break command:
while (condition1)
    if (condition2)
        break            //break here
    end
    //break continues here
end
//and not here
Is this a real thing? Maybe I've missed something, is there a way to break the loop like in other languages?
If this is not possible, I may have an idea: add an optional argument for the break command, to jump through a given number of end statements. This is compatible with the previous behaviour and it's even better than the solutions of many other languages (it can jump out from embedded loops).
I mean this:
while (condition1)
    if (condition2)
        break 2           //break here
    end
end
Mike
Re: break instruction
Post by Mike »
I think you will have to forget using the 'break' instruction :|
TVPaint Team
schwarzgrau
Post by schwarzgrau »
Is there some workaround to abort the loop ?
schwarzgrau wrote:Is there some workaround to abort the loop ?
Using an "EXITFLAG" will do it...
schwarzgrau
Thank you again Sven
