Is there a flipbook shortcut key?
brunesku
Post by brunesku »
Hello!
Is it possible to set a keyboard shortcut for flipbook?
To have a key pressed and maybe click and drag the cursor as you normally do by pressing the flipbook icon? I find the icon too small for me and keep missing it and also would like to be able to flip without moving my eyes from the drawing.
Or maybe to be able to assign it on the wacom touch strip(i have allready assigned it to go left and right one frame on the timeline but find it a bit hard to control)
I would like to simulate as much as possible the traditional way of having a few papers between my fingers while drawing.
Don't get me wrong, i love the flipbook feature as it is allready :)
Thanks for any advice or tip!
neonnoodle
Re: Is there a flipbook shortcut key?
Post by neonnoodle »
Yes, it's in the keyboard shortcuts under Preview: Freehand Flipping
brunesku
Post by brunesku »
Thank you neonnoodle! That's perfect!
schwarzgrau
Post by schwarzgrau »
I searched this shortkey a few minutes ago and it was pretty hard to find. I remembered that there was a button with the same function if I switch from fullscreen to windowed. But this button is called flipbook. Since I didn't found "flipbook" in the shortcuts I had to search the forum.
Maybe the shortcut and the button should share the same name.
brunesku, are you using TVPaint Animation 9, 10 or 11 ?
There are a lot of improvements in the v11 regarding the flipping (especially the option "manual flipping")
NathanOtano
Post by NathanOtano »
schwarzgrau wrote:I searched this shortkey a few minutes ago and it was pretty hard to find. I remembered that there was a button with the same function if I switch from fullscreen to windowed. But this button is called flipbook. Since I didn't found "flipbook" in the shortcuts I had to search the forum.
If i'm correct, the shortcut does'nt exist in tvpaint 11 anymore. And for slow computer it was kind of faster than the actual flip panel.
no : "basic flip" in v11 has the same speed than flip in the v9 or v10 (because same code behind), you can even set the speed.
schwarzgrau
Sorry I still don't get it. What do I have to do if I want to set up a shortcut for stylus flipping?
what is the TVPaint Animation version we are talking about ? Without this basic information, I can't provide any tech support.
schwarzgrau
I'm using 11.0.2, as written in my signature. I guess brunesku already has an answer, since his post is from January.
I guess brunesku already has an answer, since his post his from January.
ah ok, I didn't notice :oops:
for more informations about the flips in v11 :
http://www.tvpaint.com/doc/tvp11/index. ... esentation" onclick="window.open(this.href);return false;
a lot of customizations can be done.
schwarzgrau
Wow I ran over the flip-panel when it was new, but didn't notice HOW precise you can adjust your Flips. Thank you a lot Fabrice.
NathanOtano
Fabrice wrote:no : "basic flip" in v11 has the same speed than flip in the v9 or v10 (because same code behind), you can even set the speed.
I was talking about manual flip, I missread the first question sorry :S
condepablo
Post by condepablo »
Hi! im using tvpaint 11.0.9
and i wanna know if there is any way to set the flipbook this way: by pressing a key, plays automaticly (at the frame rate on the remote control) 15 frames (aprox) pre and post the frame where i stand.
the "flip basic" do a ping pong, and i just want to be a loop play.
i can use the mark in and mark out. but it would be much faster and useful to me if the flip key work that way.
thanks!
Hironori Takagi
Post by Hironori Takagi »
Please try the attached method.
・Use Flip Directional with Limits:Custom / check Come back to origin / check Loop between limits
