Execute command line with TVP Topic is solved
tokejepsen
Post by tokejepsen »
Hey,
Could only find ways of executing a script in TVP from the command line.
Is there a way to execute a command line from within TVP?
Re: Execute command line with TVP
tokejepsen wrote:...
I'm not sure to understand what's you're exactly looking for,
but you can embed any script command in a custom button,
then assign this button (the embedded command) to a shortkey,
you also have a special command to launch a longer script :
tv_runscript myscript.grg
(tvpa v10 or up required I think)
tokejepsen
Thanks ZigOtto:)
Don't know why I didn't try batch scripts, but it works!
tv_runscript "myBatch.bat"
Now the question is how to pass arguments to the batch script. Either of these two work;
tv_runscript "myBatch.bat" --data key1 value1
tv_runscript "myBatch.bat --data key1 value1"
If this is not possible, then I'll just write a temporary batch file and execute that.
tokejepsen
I tried exploring writing a bat file out, but I can't get this to work;
tv_WriteTextFile "C:/Users/toke.jepsen/Desktop/temp.txt" "Line to write"
On startup TVP asks to the "Write to file", but executing more times and nothing happens. It also doesn't actually write the file.
Has anyone used "tv_WriteTextFile" successfully?
afaik, (tv_WriteUserString and tv_ReadUserString work as expected,
they are used in many scripts from the content sharing section,
to store and retrieve tvpaint data (text or values) from one session to the other, these 2 commands require "Section" and "Argument" parameters, to indicate precisely where to write/read the text file within the config file,
tv_WriteUserString  section line text
Writes a character string to the current configuration file. The section argument is the name of the section, and the line argument is the name of the line in which the text string is to be written. These arguments must be surrounded by double quotes. This command is used to store variables between two working sessions using George and TVPaint and to read them using tv_ReadUserString. (However take care not to put too many character strings into the configuration file).
tokejepsen
Thanks ZigOtto:)
I've used
tv_WriteUserString
and
tv_ReadUserString
successfully. The problem is writing out a file to disk with
tv_WriteTextFile
Mads Juul
Post by Mads Juul »
tokejepsen wrote:I tried exploring writing a bat file out, but I can't get this to work;
You forgot "Create"
This code will work
Param none
tv_writetextfile "Create" "C:\test\test.txt" "Hello World"
read about it here
http://wiki.tvpaint.fr/index.php?title=Tv_WriteTextFile" onclick="window.open(this.href);return false;
I dont think there is a way to execute Command line directly in TVPaint. Is there Developers?
It could be handy I would use it.
I have a small script in Python than looks in a folder. Then I can write a text file from TVpaint in this folder the python script will notice and execute the command
http://timgolden.me.uk/python/win32_how ... anges.html" onclick="window.open(this.href);return false;
tokejepsen
Thank you Mads:)
That worked a treat!
So what I'm having a some trouble with now, is how to write double quotation marks. The current workflow is to write a temporary bat file, and run it. This way I can add arguments to the bat file and "tv_runscript" to run the bat file.
I'm passing in the original bat file, I want to execute with some arguments from a user string, and the destination path for the temporary bat file;
tv_ReadUserString pyblish script
PARSE result pyblishScript
tv_ReadUserString pyblish path
PARSE result pyblishPath
script = pyblishScript' --data key1 value1'
tv_WriteTextFile "Create" '"'pyblishPath'"' script
tv_runscript pyblishPath
tv_WriteTextFile "Remove" '"'pyblishPath'"'
What I can't seem to get working is how to write double quotation marks around the path to the original bat file. Anyone got an insight on this?
Mads Juul
Post by Mads Juul »
Pretty clever to run a .bat file with tv_runScript I didn't knoe it could do this . I only thought it would rum George Scripts. Maybe it also could run Python Scripts?
tokejepsen wrote: What I can't seem to get working is how to write double quotation marks around the path to the original bat file. Anyone got an insight on this?
I can't male it work either :( . Maybe the developers can help?
tokejepsen
You probably could, else you could run a bat file that runs the python script:)
try first setting quotes around path and filename in a variable:
PathFileName = CONCAT(pyblishPath,pyblishScript)
PathFileName = '"'PathFileName'"'  // apply quotes here
tv_warn PathFileName   // check that the path and filename are contained in quotes as you want it...
tv_WriteTextFile "Create" PathFileName Script
I think tv_WriteTextFile doesn't accept inserting the needed quotes while executing the command.
tokejepsen
Thanks Sven:)
I tried setting the quotation marks before, but it just seems to ignore it when writing to disk. Here a test case;
script = 'somethingInQuotes'
script = '"'script'"'
PRINT script
tv_WriteTextFile "Create" "C:\Users\toke.jepsen\Desktop\temp.txt" script
It prints the quotation marks, but TVP doesn't write the quotation marks to the text file.
Mike
Post by Mike »
Try this ?
script = 'xxx bla"bla"bla xx'
PRINT script
But I think it can be problematic if you want to write single-quote AND double-quotes with the same command.
TVPaint Team
tokejepsen
Thanks Mike:)
Your code works, but the problem is when you have the quotation marks at the beginning of the string;
script = '"bla" bla xx'
PRINT script
tokejepsen
More to this. The problem actually seems to be with whitespace before or after the quotation marks.
script = 'xxx bla "bla"bla xx'
PRINT script
