Move cursor if not on a frame
Lukas
Post by Lukas »
the image I attached shows what I'm trying to do...hopefully :)
I'm making some buttons that travel to the layers I need to go to often, so I don't have to manually find the layers (working on some projects with lots of layers), they work great, but now I only need to move the time-cursor if its next to the actual frames of the particular layer.
Is it possible with george?
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Lukas
Re: Move cursor if not on a frame
Post by Lukas »
Nevermind, I figured it out :)
tv_LayerGetImage
CurrentFrame = result
tv_FirstImage
FirstFrame = result
tv_LastImage
LastFrame = result
IF CurrentFrame < FirstFrame
tv_LayerImage FirstFrame
END
IF CurrentFrame > LastFrame
tv_LayerImage LastFrame
END
  • LukasKrepel.nl
that said, do you know the following shortcut [,] (click anywhere on your image, assuming there are several layers involved : you should be able to select the layer you want)
Lukas
Post by Lukas »
Yes I do, it's a lovely shortcut :) But it only works if the layers are in the display, I often want to go somewhere even if its a hidden layer etc.
But I needed some more specific buttons. I'm working on a project for a long period, with 3 characters. And I made 3 buttons to jump to the specific character's line art and hide all other layers.
// this button would expose and go to the layer called "vader lijn" which is in colorgroup 2, but still show the background (which I've set to 20% opacity with another button
group = 2 // Character's colorgroup
BGgroup = 9 // Background's colorgroup
character = vader // Name of character
line = lijn // Dutch translation
color = kleur // Dutch translation
shadow = schaduw // Dutch translation
detail = detail // Dutch translation
tv_layercolor hide Display 1
tv_layercolor hide Timeline 1
tv_layercolor hide Display 2
tv_layercolor hide Timeline 2
tv_layercolor hide Display 3
tv_layercolor hide Timeline 3
tv_layercolor hide Display 4
tv_layercolor hide Timeline 4
tv_layercolor hide Display 5
tv_layercolor hide Timeline 5
tv_layercolor hide Display 6
tv_layercolor hide Timeline 6
tv_layercolor hide Display 7
tv_layercolor hide Timeline 7
tv_layercolor hide Display 8
tv_layercolor hide Timeline 8
tv_layercolor hide Display 9
tv_layercolor hide Timeline 9
tv_layercolor hide Display 10
tv_layercolor hide Timeline 10
tv_layercolor hide Display 11
tv_layercolor hide Timeline 11
tv_layercolor hide Display 12
tv_layercolor hide Timeline 12 // hide alles
tv_layercolor show Display group
tv_layercolor show Timeline group
tv_layercolor show Display BGgroup
tv_LayerCurrentID
Beginlayer = result
layerRun = 1
layerPos = 0
WHILE layerRun
	tv_LayerGetID layerPos
	lid = result
	IF CMP(lid,"NONE")==0
		// START RUN ON LAYER
tv_LayerInfo lid
PARSE result layerDisplay layerPosition layerOpacity layerName layerType layerStart layerEnd layerPrelighttable layerPostlighttable layerSelection
PARSE layerName word1 word2 word3 word4
tv_layercolor get lid
GroupColor = result
IF CMP(GroupColor, group)
      IF CMP(word2, color)
            tv_LayerDisplay lid Off
      END
      IF CMP(word2, detail)
      END
      IF CMP(word2, shadow)
      END
      IF CMP(word1, character)
            IF CMP(word2, line)
            Targetlayer = lid // found character line art
            END
      END
END
		// END RUN ON LAYER
		layerPos = layerPos+1
	ELSE
		layerRun = 0
	END
END
tv_layerSet Targetlayer // zet alle kleur detail en schaduw uit en ga naar vader lijn laag
tv_LayerGetImage
tv_FirstImage
FirstFrame = result
tv_LastImage
LastFrame = result
END
END // Go to start or end frame if neccesary
I did the same thing for props / FX / BG etc.
Every character has its layer this way:
Father line
Father shadow
Father detail
Father color
The second word is kind of like a secondary group... :) So for example, I can turn off ALL color layers in the entire project etc.
I'll try to share the whole panel when I can got the code less project specific.
  • LukasKrepel.nl
