Layer:Next Lighttablemode And Layer:Previous lighttablemode
Kwadrope
Re: Layer:Next Lighttablemode And Layer:Previous lighttablem
Post by Kwadrope »
+1
Jesoped
Post by Jesoped »
I say - bring it on! ; )
Yes!
I too feel this was a very valuable and fruitfull discussion and it would be great if something could be done with (some of) the ideas mentioned.
but maybe with others command's apellations, because I'm afraid the name here isn't very clear,
or could be confused with "Toggle Light-Table mode", which is in the LT settings panel [Frame>Instance>Bookmark>...]
Mads Juul
Post by Mads Juul »
What about
Layer : Next Image From Light Table Loop
Layer : Previous Image From Light Table Loop
Important to remember that if the Light table is disabled the functions will still go to next Image from Light table.
For Instance If Light table Mode is set to "Bookmarks" and lighttable is disabled I will still go to next bookmark when i press
-Mads
Mads Juul
Post by Mads Juul »
Just to be clear. This is a feature request to implement my scripts "Flip Bin" http://www.tvpaint.com/forum/viewtopic. ... bin#p18513
Directly into TVP. to make it work with all lighttable modes and to make it faster. but essentially it is the same feature.
-MAds
Mads Juul
Post by Mads Juul »
Reading through the feature request to see whats being requested and whats implemented. I found out this request is a duplicate of this
viewtopic.php?f=21&t=3662&hilit=flip+bin
And I I just one to collect two comments from that topic in here
D.T. Nethery wrote:
madsjuul wrote:I think the functionallity of the flip part of my "Mads Juul Panel" Which I released in the content sharing should be part directly in the software.
That means a funtion that goes to next instance if the lighttable is in instance mode or bookmarks if the lighttable is in bookmark mode. I think this is the default function that all(most) animators would want and it should be assigned to the left/ right arrow keyboard shortcuts as default.
-mads
I AGREE !
And
Paul Fierlinger wrote: But I would also VERY MUCH welcome a single pair of key command that would advance left and right to bookmarks, instances or frames -- all depending on what one selects in the LightTable. That would be such a Key Saver!!!
it makes sense. ok :)
elmisilhumano
Post by elmisilhumano »
I think we really need this feature.
M.
Mikko Vormala
Mads Juul
Post by Mads Juul »
It's starting to be an old request
http://forum.tvpaint.com/viewtopic.php? ... ads#p29341
And it seems like A lot of people would fing it helpfull
-Mads
Thanks for pushing it again.
Sewie
Post by Sewie »
It would be a great asset!
i agree this should seriously be considered for v11
We could extend this feature to the image marks too.
So, the behavior would be :
• LT using "Instance mode" > arrows move between instances' heads
• LT using "Frame mode" > arrows move between frames
• LT using "Bookmark" > arrows move between bookmarks
• LT using "Image Marks" > arrows move between marked images
• No LT > arrows move between frames
Do you think this automatic behavior should be a parameter (maybe some people just want to move from heads to heads, or images to images ?)
Mads Juul
Post by Mads Juul »
Elodie wrote: • No LT > arrows move between frames
NO! It is extremely Important for this feature that this feature should work the same WHen the Lighttable is enabled and disabled . EXTREMELY IMPORTANT!
I have mentioned it here
http://forum.tvpaint.com/viewtopic.php? ... 440#p37137
It is useless if doesn't
