More Clear mark in and mark out
Re: More Clear mark in and mark out
Finally, I prefer your version "all in grey", than the second one =)
EDIT: I prefer the all in grey. But no matter what a more clear indication would be nice.
Maybe I also do. It is definitely more clear with all grey.Elodie wrote:Finally, I prefer your version "all in grey", than the second one =)
I think a clear indication of mark in and out and when they are enabled is needed. but then again it shouldn't interfere with other workflows
I like the top one better. Maybe you should number them...?madsjuul wrote:![]()
Sewie wrote: I like the top one better. Maybe you should number them...?
Here is my Number 8.
Yes! I like number 8.
Keep in mind that this also has to work with different interface colours - I use the very dark "Mirage" one, so I'd think the bright yellow would work fine.
[quote="slowtiger"]Keep in mind that this also has to work with different interface colours - I use the very dark "Mirage" one, so I'd think the bright yellow would work fine.
I like this also . meybe not yellow but just brighter?
Hope a feature like this one way or another will be implemented
-Mads
-Mads
I like this also . meybe not yellow but just brighter? Like current frame.slowtiger wrote:Keep in mind that this also has to work with different interface colours - I use the very dark "Mirage" one, so I'd think the bright yellow would work fine.
IF mark in and mark out is disabled the highlight is from start image to and image.
If mark in is enabled and mark out disabled the highlight is from mark in to last image and vica versa
-Mads[/quote]
- Eric Scholl
Yellow is already used for selection.
I like grey, but maybe is it to much to color all layers in grey... So I prefer to color only the top.
I was going to say the same thing =)Eric Scholl wrote:Yellow is already used for selection.
I'm working with the dark (Mirage) interface too but I don't see a problem:slowtiger wrote:Keep in mind that this also has to work with different interface colours - I use the very dark "Mirage" one, so I'd think the bright yellow would work fine.
And with the dark overlay 10% lighter:
(etc.)
(etc.)
- Timeline selection3.jpg (87.49 KiB) Viewed 23699 times
I like the all Grey(Number 8.) the most. I think the color and opacity should be adjustable and enable/disable in the display panel like the Passe partout. then if you donøt want this timeline "passepartout" then simply leave it disabled. and if you need another color because of the interface then change it.
-Mads
-Mads
- elmisilhumano
+1madsjuul wrote:I like the all Grey(Number 8.) the most.
-Mads
Mikko Vormala
