export problem
marjolein
export problem
Post by marjolein »
I sadly have a problem exporting my animation
Im verly new to tvpaint (just to keep that in mind)
The problem:
When i export my animation to quiktime it makes 200 diffrent clips of 1 second instead of 1clip of my animation.
HELP !!!! WHAT MUST I DO ?
ematecki
Re: export problem
Post by ematecki »
In the "Export" dialog you must select "Animation", not "Sequence".
marjolein
Re: export problem
Post by marjolein »
ematecki wrote:In the "Export" dialog you must select "Animation", not "Sequence".
i have it set on animatie but still same problem :(
Re: export problem
which version do you use ? don't forget to update :)
marjolein
Re: export problem
Post by marjolein »
Elodie wrote:which version do you use ? don't forget to update :)
8.5 but that shouldt make a diffrent would it?
Re: export problem
Do you have the lastest update ? it should be 8.6.4 in your case.
If not, we can not promise that there is no bug, it's important to have an up-to-date product, especially for everything related to export formats.
here is the export panel as it should be.
marjolein
Re: export problem
Post by marjolein »
Fabrice wrote:Do you have the lastest update ? it should be 8.6.4 in your case.
thanks for the reply
i got i good now it exported :D
no qlue how but it worked XD
