I am doing a free project for the 11 Second Club. However, the sound clip I use is presenting me with problems. When I scroll through the sound clip when it's already implemented in the project, to hear where to place each accent, it's fine. But when I press play, the playback is too slow and doesn't correspond with the sound.
Can anyone tell me why this is and what I can do to counter it? It's really starting to set me back. Thanks in advance.
This usually has something to do with the project's frame rate settings. Does your frame rate in your camera preferences have the same settings as your playback?
Paul http://www.slocumfilm.com
I presume (but can be wrong) that you are using the simple camera within the Tool set. Click on Preferences in the camera's panel and make sure that the frame rate is the same as your project's rate. To check that one, hover your mouse over the very top of the Project window's frame, making sure you have InLine Help under the Help menu set to at least Short.
The frame rate showing at the bottom of the Project Window is selectable and you might have changed that one at some point. Make sure all three of these places show the same speed.
My InLine help is set to Full and the Project window shows 25 fps, just like my Modify Project settings show. By Camera panel, do you mean the one just beneath the work area, with the Play and Stop buttons, where it shows the frame rate? Because that's also 25 fps.
The camera has a little camera icon and is located in the Main Panel, last icon, second row. But since you don't know about this, I doubt the problem is there (check it out though). I entered Slow Sound in the search window at the top and found this thread (there are more): http://www.tvpaint.com/forum/viewtopic. ... d&start=15" onclick="window.open(this.href);return false;
Also - it might be worth seeing if 'Play All' is ticked in the 'Preview Settings' menu. With this ticked, TVP is forced play all the frames during playback, even if this affects the correct playback rate.
1) adjust your playback settings: rightclick the green proxybar and set it to a lower quality percentage
and
2) until you solve this problem you can work around by rendering your linetests as a quicktime in a smaller resolution ( to be sure it plays smooth)
Peter Wassink - 2D animator • PC: Win11/64 Pro - AMD Ryzen 9 5900X 12-Core - 64Gb RAM
