How to change the size of the project
Hosni
Post by Hosni »
hello
i want to know if there is possibility to make a rough animation sketches in low dimension first... then cleaning and posting in HD dimension from the same project
i know i can make it in small size then export and import again in the new size project but then i will lose the dimension position of my character and needed to edit it one by one
if their any trick or way to solve it
thanks
Byron
Re: How to change the size of the project
Post by Byron »
You can go to Project > Modify Project. Not sure if that's what you're after.
Hosni wrote:... but then i will lose the dimension position of my character and needed to edit it one by one
can you explain that ? ... I don't get this point . :?
Hosni
Post by Hosni »
Byron wrote:You can go to Project > Modify Project. Not sure if that's what you're after.
thanks Byron yes that what i'm looking for
Hosni
Post by Hosni »
sorry for my bad english.. but i meant that if i import the old small project (the rough animation sketch) in the new HD project i need to scale every frame up again to fit the screen again
You don't have to do that. When you import something of a different size into a project, check "stretch to project size" (and "correct aspect" to preserve proportions). What you import will be re-sized to your actual project.
Hosni
Post by Hosni »
slowtiger wrote:You don't have to do that. When you import something of a different size into a project, check "stretch to project size" (and "correct aspect" to preserve proportions). What you import will be re-sized to your actual project.
slowtiger thank you.. it seems there many ways to do it.... i should ask you from long time..... cause i was have pain to import some sketches in Painter for enlarge it
so are there such option like in painter that add pixels space in (top , bottom , side, left)??
this option not important to me as animator.. but so important to me when i drawing some still images
thank you guys so much u so helpful guys
Hosni wrote: so are there such option like in painter that add pixels space in (top , bottom , side, left)??
that would be the Crop tool
Main Panel, second row, button nr 4
if you reset this tool (use the tool panel for this) the bounding box(red lines) aligns itself with your project and then you can use the little squares to add extra space to your project.
after you click crop (again in the tool panel) TVP copies the project to a new one with the new dimensions, so you also have the old one still there.
Hosni
Post by Hosni »
hey peter... don't know how to thank u....
really i wanna marry this software.... even don't like to call it software....
chatbraque
Post by chatbraque »
Hosni wrote: really i wanna marry this software.... even don't like to call it software....
well, let's call it… er ?… a bride ?
… well !… I'd better work a bit… 'let's call it a day" might be more suitable :D
(see you!)
Hosni
Post by Hosni »
lol yes... and she will be typical old type wife... she will never say no to me ever :D
Hosni wrote:really i wanna marry this software....
Welcome on the TVPaint community Hosni. :mrgreen:
CoreyAnimator
Post by CoreyAnimator »
This seems like the perfect place to ask...i hope you dont mind me using your thread Hosni : )
I have a question..I have a scene I am working on. I want to do a pan shot so Im using the camera tool, but i need to expand the canvas to the left in order for it tp work. I tried to crop the scene but it turned to crop every scene in my project too. Is there a way I can change the size of just that one individual scene in the animation without effecting the others?
Note:
I also tried Modify Project
I know one solution is to simply make a whole new file, but I was hoping I could prevent that some how.
There is no other way. At this point a project can hold clips of only the same size. You have to take the clip out of the project and turn it into a new project of a different size, but it's no big deal is it?
I should have mentioned that if you RMB on top of the clip or selected clips in the project tab, at the bottom of the menu you'll see "Create a new project from selected clips" and then you can rename and modify the new project and delete the clip from the original project.
