Anyone has a suggestion how to view the RGB channels as separate greyscale images?
we used to have 3 button next to the 'preserve transparency" button. but since they are gone, anyone has a method?
cheers.
greyscale RGB channels
- malcooning
Re: greyscale RGB channels
try with the Color Factory tool.
- malcooning
True. forgot about this one.
That did it.
Cheers R.
a
P.S - do you know if color factory is scriptable? Will it be possible to create a script that duplicates the image 3 times, and then applying color factory to each layer, once with rrr values, then ggg and then bbb (separate RGB values to turn each layer to it's respective greyscale)?
That did it.
Cheers R.
a
Asaf | asafagranat.com
yes it is !malcooning wrote:... do you know if color factory is scriptable? ...
tv_plugin colorop cmd r g b a
