Unknown Project Window icon
Sierra Rose
Post by Sierra Rose »
I can't find what this is or does. My "Inline help full" doesn't work anymore when I hover the mouse to see what something is/does.???
unknown icon.jpg (64.98 KiB) Viewed 16669 times
WinXP 32bit 10.0.17Pro
Re: Unknown Project Window icon
that's "include camera movement in playback".
yeap, Camera view playback, moving or not (if only one camera-frame set),
Sierra Rose wrote: ... My "Inline help full" doesn't work anymore when I hover the mouse to see what something is/does.???
Sierra, have you Help/Inline Help/Full checked on in your main menu ?
Sierra Rose
Thanks both of you. Yes, Zig....it is checked, but to no avail. :cry:
more informations here :)
http://www.tvpaint.com/training/tuto10m/tvp_camera.php" onclick="window.open(this.href);return false;
Sierra Rose
Does anyone have any ideas how I can get the inline help to work?
Also thanks for the link to the tute...very helpful.
what's your tvpa version ?
have you tried to start a new Config and see if the inline Helps work again ?
... or to update/re-install all the program ?
maybe it's something to do with your tvpaint.loc file ...
deleted, or moved at a wrong place, or corrupted ...?
a last idea : have you tried using the mouse ?
because it's hard to stay stand (still) enough time with a tablet's pen to make the inline help pop up,
it's way too sensitive, with the mouse, it's so easy, just release the device.
:wink:
Sierra Rose
Thanks so much. I changed my default config (which had all my customizations in it) to a new config which I gave some silly name. Then I went back and loaded the default again (too lazy to reset everything in a new config) and lo and behold...my inline is working in both configs! Very neat.
Anyone here friends with that camera?
i want to have one of my clips displayed more close in how would i do that?
i can only seem to get the camera to do movements.
And i just want to change the display to 150% for the length of the clip.
because i want to test the working of the shot like that, and don't want to manually modify all layers in the clip i thought i could (finally) make use of the new camera but it wont listen to me :(
You could set the expanded parameters (the setting at the bottom of the camera) or diminish the size of your image within the project window and just stretch the binding box out manually.
EDIT: sorry, you want to get closer so do the opposite of what I just said.
Peter Wassink wrote:Anyone here friends with that camera?
camera have no friends, ... only tamers ! :wink:
Peter Wassink wrote:... i can only seem to get the camera to do movements.
if you set only one frame in the camera HUD,
you shouldn't get any moving, to "crop" (zoom-in) into a clip, scale-down the camera frame (drag in one corner).
